> For the complete documentation index, see [llms.txt](https://docs.pollination.solutions/user-manual/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pollination.solutions/user-manual/rhino-plugin/pollination-commands/alphabetically/po_resetidentifier.md). Agents can also search and read this documentation through its [MCP server](https://docs.pollination.solutions/user-manual/~gitbook/mcp).
# PO\_ResetIdentifier
Reset a honeybee object's identifier and boundary condition. You can also select partial room's sub-faces for resetting boundary conditions.
## Options
* **ID**
  Reset identifier criteria.
* **GenerateNewID**
  Create a new ID randomly.
* **ByDisplayName**
  Use display name as ID.
* **ByDisplayNameAndID**
  It combines display name and random ID.
* **Face**
  Yes to reset all faces' ID.
* **Room**
  Yes to reset rooms' ID.
* **SensorGrid\_View**
  Yes to reset sensor grids' ID.
* **Validate**
  Yes to run model validation after resetting.
Notes:
* All geometries' boundary condition will be reset to Outdoor, unless geometry touches the ground (0) and then it will be set to Ground.
## Video Tutorials
{% embed url="<https://youtu.be/_Nyi8JTHpiA>" %}
How to use PO\_ResetIdentifier command
{% endembed %}
