The URL `rhino-plugin/use-rhino-scripts-to-automate-processes` does not exist. This page may have been moved, renamed, or deleted.
- [Modeling Best Practices](https://docs.pollination.solutions/user-manual/rhino-plugin/modeling-best-practices.md)
- [Getting Started in Rhino](https://docs.pollination.solutions/user-manual/rhino-plugin/getting-started.md)
- [Core Concepts & Best Practices](https://docs.pollination.solutions/user-manual/revit-plugin/core-concepts-and-best-practices.md)
- [Pollination Commands](https://docs.pollination.solutions/user-manual/rhino-plugin/pollination-commands.md)
- [Energy Modeling](https://docs.pollination.solutions/user-manual/rhino-plugin/energy-modeling.md)
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://docs.pollination.solutions/user-manual/rhino-plugin/modeling-best-practices.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/user-manual/rhino-plugin/modeling-best-practices.md`).
