The URL `get-started/account-setup/create-an-organization` does not exist. This page may have been moved, renamed, or deleted.
- [Managing Subscriptions](https://docs.pollination.solutions/user-manual/getting-started/account-setup/managing-subscriptions.md)
- [Managing License Pools](https://docs.pollination.solutions/user-manual/getting-started/account-setup/managing-license-pools.md)
- [Managing Members](https://docs.pollination.solutions/user-manual/getting-started/account-setup/managing-members.md)
- [Managing Pollination Organization](https://docs.pollination.solutions/user-manual/getting-started/account-setup.md)
- [Setting Up your Pollination Organization](https://docs.pollination.solutions/user-manual/getting-started/buying-pollination-products/setting-up-your-pollination-organization.md)
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://docs.pollination.solutions/user-manual/getting-started/account-setup/managing-subscriptions.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/user-manual/getting-started/account-setup/managing-subscriptions.md`).
