The URL `get-started/setting-up-rhino-grasshopper-and-revit-plugins` does not exist. This page may have been moved, renamed, or deleted.
- [Buying Pollination Products](https://docs.pollination.solutions/user-manual/getting-started/buying-pollination-products.md)
- [Creating a Pollination Account](https://docs.pollination.solutions/user-manual/getting-started/create-a-pollination-account.md)
- [Setting Up your Pollination Organization](https://docs.pollination.solutions/user-manual/getting-started/buying-pollination-products/setting-up-your-pollination-organization.md)
- [Creating New Pollination Subscriptions](https://docs.pollination.solutions/user-manual/getting-started/buying-pollination-products/creating-new-pollination-subscriptions.md)
- [Understanding Pollination Subscriptions Types](https://docs.pollination.solutions/user-manual/getting-started/buying-pollination-products/seats-vs-licenses.md)
Perform an HTTP GET request on the documentation index with the `ask` parameter, and the optional `goal` parameter:
GET https://docs.pollination.solutions/user-manual/getting-started/buying-pollination-products.md?ask=<question>&goal=<end_goal>
`goal` is optional and describes the broader end goal you are ultimately trying to accomplish on behalf of the user. GitBook uses it to tailor the answer towards what is most useful for that goal.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/user-manual/getting-started/buying-pollination-products.md`).
