> For the complete documentation index, see [llms.txt](https://docs.pollination.solutions/user-manual/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pollination.solutions/user-manual/grasshopper-plugin/grasshopper-user-interface/2_pollination/setup_runs.md). Agents can also search and read this documentation through its [MCP server](https://docs.pollination.solutions/user-manual/~gitbook/mcp).
# Setup\_Runs
![Setup Runs](https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2Fgit-blob-80eadb3fcc461228f6227c1e561717da6288d4a5%2FSetup_Runs.png?alt=media)
Set up a Pollination runs for a study. Double click on the component to start loading a recipe.
## Inputs
* **user\_data \[Default]**
  Use User Data component to provide additional meta data for the run. These inputs are useful to add the implicit values that you have used to prepare the input model. For instance you can use this input to add a name for each run or add a filled for window to wall ratio in your model.
## Outputs
* **run**
  A Pollination run that is for Pollinate component to execute on the Pollination cloud or your local machine. You can use CheckStudyStatus to monitor each study.
