For the complete documentation index, see llms.txt. This page is also available as Markdown.
PO_Dump_GEM
PO Dump GEM
Save entire model as GEM file
Inputs
  • model [Required]
    A Honeybee Model object to be written to a GEM file.
  • name [Default]
    A name for the file to which the honeybee objects will be written. If unspecified, it will be derived from the model identifier.
  • folder [Default]
    An optional directory into which the honeybee objects will be written. The default is set to the default simulation folder.
  • dump [Required]
    Set to "True" to save the honeybee model to a GEM file.
Outputs
  • gem
    The location of the file where the GEM file is saved.
