The URL `revit-plugin/export-analytical-model/exporting-rooms-spaces-and-areas/create-and-review-floor-plans` does not exist. This page may have been moved, renamed, or deleted.
- [Create and Review Floor Plans](https://docs.pollination.solutions/user-manual/revit-plugin/pollination-revit-classic/hands-on-tutorial/exporting-rooms-spaces-and-areas/create-and-review-floor-plans.md)
- [Step 1: Load Revit Rooms/Spaces](https://docs.pollination.solutions/user-manual/revit-plugin/export-your-first-model/step-1-load-revit-rooms-spaces.md)
- [Step 3: Add Windows & Doors](https://docs.pollination.solutions/user-manual/revit-plugin/export-your-first-model/step-3-add-windows-and-doors.md)
- [Frequently Asked Questions about Exporting Rooms](https://docs.pollination.solutions/user-manual/revit-plugin/pollination-revit-classic/hands-on-tutorial/exporting-rooms-spaces-and-areas/frequently-asked-questions-about-exporting-rooms.md)
- [Parse, Review, and Export Each Level as a Pollination Snapshot](https://docs.pollination.solutions/user-manual/revit-plugin/pollination-revit-classic/hands-on-tutorial/exporting-rooms-spaces-and-areas/parse-review-and-export-each-level-as-a-pollination-snapshot.md)
Perform an HTTP GET request on the documentation index with the `ask` parameter:
GET https://docs.pollination.solutions/user-manual/revit-plugin/pollination-revit-classic/hands-on-tutorial/exporting-rooms-spaces-and-areas/create-and-review-floor-plans.md?ask=<question>
The question should be specific, self-contained, and written in natural language.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/user-manual/revit-plugin/pollination-revit-classic/hands-on-tutorial/exporting-rooms-spaces-and-areas/create-and-review-floor-plans.md`).
