The URL `revit-plugin/export-analytical-model/selecting-roofs-optional` does not exist. This page may have been moved, renamed, or deleted.
- [Selecting Roofs (optional)](https://docs.pollination.solutions/user-manual/revit-plugin/pollination-revit-classic/hands-on-tutorial/selecting-roofs-optional.md)
- [Step 2: Add Roofs](https://docs.pollination.solutions/user-manual/revit-plugin/export-your-first-model/step-2-add-roofs.md)
- [Step 5: Export Model](https://docs.pollination.solutions/user-manual/revit-plugin/export-your-first-model/step-5-export-model.md)
- [Step 0: Getting Started Checklist](https://docs.pollination.solutions/user-manual/revit-plugin/export-your-first-model/step-0-getting-started-checklist.md)
- [Step 1: Load Revit Rooms/Spaces](https://docs.pollination.solutions/user-manual/revit-plugin/export-your-first-model/step-1-load-revit-rooms-spaces.md)
Perform an HTTP GET request on the documentation index with the `ask` parameter, and the optional `goal` parameter:
GET https://docs.pollination.solutions/user-manual/revit-plugin/pollination-revit-classic/hands-on-tutorial/selecting-roofs-optional.md?ask=<question>&goal=<end_goal>
`goal` is optional and describes the broader end goal you are ultimately trying to accomplish on behalf of the user. GitBook uses it to tailor the answer towards what is most useful for that goal.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/user-manual/revit-plugin/pollination-revit-classic/hands-on-tutorial/selecting-roofs-optional.md`).
