> For the complete documentation index, see [llms.txt](https://docs.pollination.solutions/user-manual/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pollination.solutions/user-manual/revit-plugin/export-your-first-model/step-4-add-shades.md).
# Step 4: Add Shades
<figure><img src="https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2F7Tnbv6xDPELR8nzDMQqr%2Fimage.png?alt=media&amp;token=6d3e7ed2-3846-43ae-a1be-323c238c3ec3" alt=""><figcaption></figcaption></figure>
In the fourth step, we will load any the necessary Revit elements as shading objects.
## Typical workflow
Follow these steps to add shading geometry from your current Revit selection:
1. **Select in Revit**: Highlight the elements in your Revit model that you want to use as shades.
2. **Load Selection**: Click "Add Shades from Revit" to import your current selection into this menu.
3. **Review & Filter**: Right-click any item to Review or Select it in Revit. Uncheck the "Export" box to exclude specific items from the final model.
4. **3D Preview**: Click Preview to inspect the geometry.
5. **Finalize**: Click Add Shades to Model to complete the process.
### Pro Tip
If your selection includes curved or non-planar geometry, ensure "Ignore Non-Planar Faces" is unchecked in the settings. You can also adjust the "Mesh Detail" value to control the accuracy of the resulting mesh.
## Pollination model
<figure><img src="https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2FDChIGT06zgUT6YfoSTzP%2F7-load-shades.jpg?alt=media&amp;token=a1280494-c21d-438d-ab17-6e494c680102" alt=""><figcaption><p>Load shades from Revit</p></figcaption></figure>
<figure><img src="https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2FkhttRLuEnDrteruJuOHF%2F8-add-shades.jpg?alt=media&amp;token=920e4732-b754-489b-a75c-a8728896407b" alt=""><figcaption><p>Pollination model with shades</p></figcaption></figure>
{% file src="/files/rUjGIPomIT3RPK9YV27b" %}
## Video tutorial
{% embed url="<https://youtu.be/B0MbNy-RYdc>" %}
