# Merging Levels into a Single Snapshot
{% embed url="<https://youtu.be/KLCwLJqrM70>" %}
For anyone who might need the files, here are the files you'll need to follow this section.
{% file src="<https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2FKxR5m7u5jkSjo2Nz210A%2F01%20-%20Entry%20Level.pomf?alt=media&token=eda80a20-bde8-4201-b88d-155b8ef77b65>" %}
{% file src="<https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2FW7hb6ExflT4J4GgOlQfG%2F02%20-%20Floor.pomf?alt=media&token=b4e31bf2-1aeb-421f-a0c5-adc65a495822>" %}
{% file src="<https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2F8Habb6MGfAQ77aezPSku%2F03%20-%20Floor.pomf?alt=media&token=14bff0c7-ce4e-43af-a5e4-0e6ce76692b1>" %}
Before starting the cleaning process, let's combine all the levels together.
1. Click on `File > Open` and open the .pomf file for level 1 (01 - Entry Level.pomf).<br>
   <figure><img src="https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2FB5TnjnwJP03KDeSdxv4I%2Fimage.png?alt=media&#x26;token=5d1956c8-42dd-44d2-921c-081caec6a0fd" alt=""><figcaption></figcaption></figure>
2. Use `File > Save As` to save it as a new Pollination model. Let's name it Full Model.pomf.<br>
   <figure><img src="https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2F9xdRdj4IpIeTSssjqsnN%2Fimage.png?alt=media&#x26;token=7fb2c3a4-ae2f-4061-9cfe-403e5cc50645" alt=""><figcaption></figcaption></figure>
3. Use `File > Open` to open the new model (Full Model.pomf).
4. Now use `File > Import` to import `02 - Floor.pomf` and `03 - Floor.pomf` into the full model file.<br>
   <figure><img src="https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2FPfGo7Sbou5Ldm093TqUI%2Fimage.png?alt=media&#x26;token=9c27bbd0-eb76-438c-8b33-542d9c0b462c" alt=""><figcaption></figcaption></figure>
You may need to turn on the visibility of the level after importing them if the visibility is off by default.
<figure><img src="https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2FedZq7dvKTL9MsrhABU8C%2Fimage.png?alt=media&#x26;token=a83a340f-4191-4b18-bdeb-23aba21eb12b" alt=""><figcaption><p>Click on the eye to change the visibility of the level</p></figcaption></figure>
Press `Ctrl + A` to select all the rooms, click on the Preview button, and press OK to see the 3D preview.
<figure><img src="https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2FXZsC1abSRCXu2bPiOHAN%2Fimage.png?alt=media&#x26;token=01c9d274-db84-40da-b31c-7e720d09491e" alt=""><figcaption></figcaption></figure>
Congrats! You're ready to start editing the model.
