# Exporting the Valid Model
{% embed url="<https://youtu.be/yvyzjcKcWkM>" %}
If you need the files, here are the files you'll need to follow along this section.
{% file src="/files/oublZ3YRMW8KNDhzuauy" %}
Here is a copy of the final model after validation.
{% file src="/files/cwRqYk7gxvxz7zKEQPYA" %}
Well done! Time to enjoy the outcome of your work. Click the export button, and export the model to any of the supported file formats.
<figure><img src="/files/B1BSCf1fsD7xGDjbQLOU" alt=""><figcaption></figcaption></figure>
If no geometry is selected, Pollination exports all the rooms and shades in the model. But if you select any of the rooms or shades, it will only export the selected items.
Here is a copy of the PoMF file.
{% file src="/files/ulJ3ZXal6xBVB6rovp36" %}
For this tutorial, we will export the model to Pollination Rhino (.HBJSON), IESVE (.GEM), eQuest (.INP), DesignBuilder (dsbXML), OpenStudio (.OSM), and gbXML. See below for a screenshot of each exported model, and download the export files.
[You can learn more about all the supported file formats and the export options here](/user-manual/model-editor/supported-file-formats/export.md).
### Pollination Rhino (.HBJSON)
<figure><img src="/files/hI365mF4Xq0GbwhvWkLG" alt=""><figcaption><p>Revit sample model in [Pollination] Rhino (.HBJSON)</p></figcaption></figure>
{% file src="/files/61M8XhFMoH8CdA42OUPi" %}
### IESVE (.GEM)
<figure><img src="/files/eE61gi2nXmQXLmBi58Lj" alt=""><figcaption><p>Revit sample model in IESVE (.GEM)</p></figcaption></figure>
{% file src="/files/w6xGO6f5KlmrZtnXsg73" %}
### eQuest (.INP)
<figure><img src="/files/AUm1JJU8ZXIwViigPogF" alt=""><figcaption><p>Revit sample model in eQuest (.INP)</p></figcaption></figure>
{% file src="/files/Ihn6xuCvON0OxJT6igq2" %}
### DesignBuilder (.dsbXML)
<figure><img src="/files/2z3oIhZsKZqjDbrFkdrY" alt=""><figcaption><p>Revit sample model in DesignBuilder (.dsbXML)</p></figcaption></figure>
{% file src="/files/NoGtI8Ea4sGdNefFbNwB" %}
### OpenStudio (.OSM)
<figure><img src="/files/XqgK3romnMACNmcoOlml" alt=""><figcaption><p>Revit sample model in OpenStudio (.OSM)</p></figcaption></figure>
{% file src="/files/AQT4GlaT73L3eQeGw0DJ" %}
### gbXML
<figure><img src="/files/sIJzr5doEYuMMdyvy7Nf" alt=""><figcaption><p>Revit sample model in Spider (.gbXML)</p></figcaption></figure>
{% file src="/files/RKdbIEXlwMT9WEDb5jJ7" %}
In addition to the software that we listed above you could use the gbXML export to import the model to many other software including but not limited to Career HAP, and EDSL Tas. We also provide a modified version of the gbXML format optimized for TRACE 700, and TRACE 3D Plus.
<figure><img src="/files/X9QiLznt1lHJbU5OCJ5S" alt=""><figcaption><p>Revit sample model in Tas (.gbXML)</p></figcaption></figure>
<figure><img src="/files/Z7J7HBJDGCde6GWChfzE" alt=""><figcaption><p>Revit sample model in TRACE 3D Plus (.TRACEXML)</p></figcaption></figure>
<figure><img src="/files/VoXzeLhkqxczVmnQJRki" alt=""><figcaption><p>Revit Sample Model in HAP 6.3 (.gbXML)</p></figcaption></figure>
# Agent Instructions: Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation dynamically by asking a question.
Perform an HTTP GET request on the current page URL with the `ask` query parameter:
GET https://docs.pollination.solutions/user-manual/revit-plugin/pollination-revit-classic/hands-on-tutorial/getting-started/exporting-the-valid-model.md?ask=<question>
The question should be specific, self-contained, and written in natural language.
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
