> For the complete documentation index, see [llms.txt](https://docs.pollination.solutions/user-manual/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pollination.solutions/user-manual/rhino-plugin/daylight-modeling/add-view.md).
# Add View
Add a camera view for Radiance's view based simulation
{% embed url="<https://youtu.be/XG0s2WNHAmU?t=136>" %}
Command [PO\_AddView](https://docs.pollination.solutions/user-manual/rhino-plugin/pollination-commands/alphabetically/po_addview.md) provides two options to create camera views: from points and from the current view.
**From points:** users can create camera views directly from points in Rhino, and default view orientation is facing along with Rhino's X axis. However, it can always be relocated and rotated afterwards.
![](https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2Fgit-blob-f045adfb2f77a0287bd2eff30749baad13c29313%2Fimage.png?alt=media\&token=7334b2d0-0221-4ec8-b6ac-09c8e0047c1d)
**From current view**: users will need to adjust current active Rhino view to a location and orientation before running the command PO\_AddView. This command will translate current Rhino view to a view point object.
![Adjust the current Rhino view](https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2Fgit-blob-e887b6f8325736748bcab7f12eba7dfb1c192a68%2Fimage.png?alt=media\&token=baf2565b-95d7-4923-a908-9e986331203f)
