Cleaning Up and Exporting the Snapshots
Once you have the snapshots, you can use the Pollination Model Editor to clean them up quickly and export them to any of the supported file formats.
This section is a work in progress and currently doesn't include videos. If you prefer learning by watching videos, see this page.
To open the Model Editor, click the "Export Model" button.
You should see the 3 snapshots for the levels and the snapshot for shades on the right side. For the rest of this tutorial, we will use the Pollination Model Editor to export the Snapshots as an energy model.
For this specific model, we will merge the snapshots before starting the clean-up, but for larger models with more levels, you may want to clean up the snapshots for each level first, before combining them into a single snapshot.
Understanding a Typical Editing Process
The process for editing models can vary on a model-by-model basis. But in most cases, it includes 5 typical steps:
Fix visible misalignments and gaps
Fill holes with rooms, and merge smaller rooms
Check for small misalignments and gaps
Ensure model validation
Edit slanted and extended roofs
In this section of the tutorial, we will go through these steps to clean the Revit sample model.
For Those Who Want to Know More
You can read more about each step of a typical clean-up process on this page. There are also other optional steps that you might want to take to increase the quality of your model:
See here for a collection of the most common Model Editor workflows.
