> For the complete documentation index, see [llms.txt](https://docs.pollination.solutions/user-manual/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pollination.solutions/user-manual/rhino-plugin/getting-started.md).
# Getting Started in Rhino
There are several interfaces and interaction points for Pollination in Rhino.
* [Pollination Room Manager](#pollination-room-manager): An icon and table-based interface allowing for analytical model creation, editing, and management.
* Pollination Panel: Brings the Pollination [Web Platform](https://app.pollination.solutions/) into Rhino.
* [Pollination Commands](#pollination-commands): Type in commands from getting a license to building a shade element.
## Pollination Room Manager
To pull up the Pollination Room Manager, type `Pollination` in the command line. Once you hit Enter, a panel will emerge that you can dock in your window as you would a native Rhino panel.
{% embed url="<https://youtu.be/qJQCc59EdCw>" %}
## Pollination Panel
To access apps from within Pollination, type `PO_Panel` in the command line.
## Pollination Commands
A list of Pollination Commands for Rhino with detailed descriptions is available in this user manual. You can also type "PO\_" in the command line to preview a list of commands in Rhino.
{% content-ref url="/pages/-Mco\_BJyj4aNyt0be67X" %}
[Pollination Commands](https://docs.pollination.solutions/user-manual/rhino-plugin/pollination-commands.md)
{% endcontent-ref %}
### Native Rhino Command Compatibility
Besides custom Pollination commands, several native Rhino commands can be used to modify custom Pollination RhinoObjects.
|                              ACTION                             | COMMAND LINE | GUMBALL | KEYBOARD SHORTCUT |
|                          Copy / CTRL+C                          |     **✔**    |  **✔**  |       **✔**       |
|                           Cut / CTRL+X                          |     **✔**    |         |       **✔**       |
|                          Paste / CTRL+V                         |     **✔**    |  **✔**  |       **✔**       |
|                          Undo / CTRL+Z                          |     **✔**    |         |       **✔**       |
|                          Redo / CTRL+Y                          |     **✔**    |         |       **✔**       |
|                              Delete                             |     **✔**    |         |       **✔**       |
|              Move / GumballDrag / GumballTransform              |     **✔**    |  **✔**  |                   |
|  <p>Move Sub-Geometry</p><p><em>(Hold Shift+Ctrl keys)</em></p> |     **✔**    |  **✔**  |                   |
|                    Scale / Scale1D / Scale2D                    |     **✔**    |  **✔**  |                   |
|                        Rotate / Rotate3D                        |     **✔**    |  **✔**  |                   |
|                       MoveFace / MoveEdge                       |     **✔**    |         |                   |
| <p>Explode</p><p><em>(RoomObject=> OrphanedFaces only)</em></p> |     **✔**    |         |                   |
|       <p>Join</p><p>(OrphanedFaces => RoomObject only)</p>      |     **✔**    |         |                   |
|                      SplitFace / MergeFace                      |     **✔**    |         |                   |
|                            Flip / Dir                           |     **✔**    |         |                   |
|                               Cap                               |     **✔**    |         |                   |
|                   Trim / Untrim / UntrimHoles                   |     **✔**    |         |                   |
|                              Mirror                             |     **✔**    |         |                   |
|                      MergeAllCoplanarFaces                      |     **✔**    |         |                   |
![Undo and Redo Commands](https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2Fgit-blob-15a72a179f772f0adcd41cf8e423093320b2b357%2FUndoRedo.gif?alt=media\&token=51349b8b-931d-4a6e-8e6a-458465495250)
![Move Face & Move Edge Using Rhino Command line](https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2Fgit-blob-0985fd328e14206d0828e38d69a487c4729e63c6%2FMoveFace_MoveEdge_CMD.gif?alt=media\&token=cfac463e-886f-4ff3-8f5f-0ee81d0bb930)
![Move Face & Move Edge Using Gumball](https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2Fgit-blob-696f65ca4dba908d1c82629f5ed50423a5d7fc71%2FMoveFace_MoveEdge.gif?alt=media\&token=4ebfe98b-ed8f-4c0b-ada4-299cc29b62ba)
