For the complete documentation index, see llms.txt. This page is also available as Markdown.
PO_Dump_INP
PO Dump INP
Save entire model as INP file
Inputs
  • model [Required]
    A Honeybee Model object to be written to a INP file.
  • name [Default]
    A name for the file to which the honeybee objects will be written. If unspecified, it will be derived from the model identifier.
  • folder [Default]
    An optional directory into which the honeybee objects will be written. The default is set to the default simulation folder.
  • hvac_mapping [Default]
    An optional input to group rooms for HVAC mapping. Valid options are: room, story, model, and assigned-hvac. The default is set to 'story'.
  • exclude_InWalls []
    Set to "True" to exclude all interior walls. The default is set to False to include all interior walls.
  • exclude_InCeilings []
    Set to "True" to exclude all interior ceilings. The default is set to False to include all interior ceilings.
  • switch_statements [Optional]
    Set to "True" to use switch statements. The default is set to False.
  • dump [Required]
    Set to "True" to save the honeybee model to a INP file.
Outputs
  • inp
    The location of the file where the INP file is saved.
