> For the complete documentation index, see [llms.txt](https://docs.pollination.solutions/user-manual/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pollination.solutions/user-manual/grasshopper-plugin/grasshopper-user-interface/4_serialization/po_dump_sdd.md).
# PO\_Dump\_SDD
![PO Dump SDD](https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2Fgit-blob-1ef9208dec321f2169a87f0a3269ecd11a2a639d%2FPO_Dump_SDD.png?alt=media)
Save entire model as CBECC Standards Data Dictionary (SDD) XML file
## Inputs
* **model \[Required]**
  A Honeybee Model object to be written to a SDD XML file.
* **name \[Default]**
  A name for the file to which the honeybee objects will be written. If unspecified, it will be derived from the model identifier.
* **folder \[Default]**
  An optional directory into which the honeybee objects will be written. The default is set to the default simulation folder.
* **dump \[Required]**
  Set to "True" to save the honeybee model to a SDD XML file.
## Outputs
* **SDD**
  The location of the file where the SDD XML file is saved.
