> For the complete documentation index, see [llms.txt](https://docs.pollination.solutions/user-manual/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pollination.solutions/user-manual/rhino-plugin/modeling-best-practices/using-room-selection-mode.md).
# Using Room Selection Mode
## **Room Selection Mode**
You can find a button to toggle `RoomSelection` mode ON/OFF in the first row of icons of the Pollination Panel. When the button is saturated, it is ON. When it is grayed out, it is OFF.
![](https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2Fgit-blob-b25c03ac3b33276188a0f8b1142f826b2d210f1e%2Fimage.png?alt=media)
### RoomSelection ON
When turned ON, you can select a room (parent) along with all its apertures, doors, and shades (child). The same effect applies to the orphaned face/aperture/door as well. This is useful when you want to transform or select rooms (move, scale, rotate, etc) without missing child surfaces.
![](https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2Fgit-blob-94349eeeb3a7683495b1982757fd3b37264feda3%2FRoomSelectionON.gif?alt=media)
### RoomSelection OFF
When turned OFF, the selection ignores all parent-child relationships. All geometries will be in an independent state, so you can select individual parent and child surfaces.
![](https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2Fgit-blob-fab89053f79869e5fdc041fefcc9ddcfaf37cbbf%2FRoomSelectionOFF.gif?alt=media)
**Rhino Selection Tip**
If you create a selection window from left to right, Rhino will only select objects that are fully within the selection window.
If you create a section window from right to left, Rhino will select all objects that both fall within and intersect the selection window.
**Pollination Selection Tip**
Combine RoomSelection OFF with [PO\_SelApertures](https://docs.pollination.solutions/user-manual/rhino-plugin/pollination-commands/alphabetically/po_selapertures.md) to select all apertures from a room, face, or building.
