Install CAD Plugins
Use the tabs to see instructions for each of our plugins.
After downloading the installers you can install the plugin by following the following steps. See the link below for silent installation.
The Pollination Rhino plugin is designed for optimal compatibility with Rhino 7 and Rhino 8.
If you are using Rhino 6, there is an incompatibility issue with the way Rhino 6 loads plugins. After installing Pollination, you will need to open and close Rhino three times to load the Pollination plugin.
The Rhino installer also includes the Grasshopper plugin. You can consider it the Pollination Rhino and Pollination Grasshopper plugin installer.
You do NOT need to install the Grasshopper plugin separately. If you do, it will remove the Pollination Rhino plugin.
Step 1
Rhino must be closed before running the installer to install or uninstall Pollination.
Double-click on the PollinationRHGHInstaller.exe file to start the installation. The installer can also be used to remove components, update Pollination, or uninstall previous versions of Pollination. If you already have a version of Pollination installed then the installer will automatically show these options.
Step 2
Follow the instructions in the Pollination Rhino Plugin Setup Wizard to install the plugin.
Troubleshooting your installation
Visit our Troubleshooting section to see common errors and installation issues.
The Pollination Revit plugin currently supports Revit 2019 - 2024. If you are using an older version of Revit, you will need to upgrade to a more recent Revit release to use Pollination.
Step 1
Double-click on the PollinationRevitPluginInstaller.exe file to start the installation. The installer can also be used to remove components, update Pollination, or uninstall previous versions of Pollination. If you already have a version of the Pollination Revit plugin installed then the installer will automatically show these options.
Step 2
Follow the instructions in the Pollination Revit Plugin Setup Wizard application to install the plugin.
Installation
Step 1
Rhino must be closed before running the installer.
The Grasshopper plugin is also packaged in the Rhino installer. You only need to install the Grasshopper plugin separately if you do NOT have the Rhino plugin installed. Installing the Grasshopper plugin will remove any previous versions of the Pollination Rhino and Pollination Grasshopper plugins.
Double-click on the PollinationGHInstaller.exe file to start the installation. The installer will automatically remove any previous versions of Pollination.
Step 2
Follow the prompts to install the plugin.
Silent Installation
For silent machine-wide installation use the command below.
Debugging Installation Issues
If you get an error during the installation see the installation log file in the %TEMP% folder or your computer. Look for a file that is named installbuilder_installer_{number}.log. You may see several log files in the folder if you have used the installer several times. You should select the file that was created last.
License Population
You do not need to populate the licenses after the installation. As long as the users have been added to the license pool they will be able to check out a license from inside the CAD plugins.
