> For the complete documentation index, see [llms.txt](https://docs.pollination.solutions/user-manual/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pollination.solutions/user-manual/grasshopper-plugin/grasshopper-user-interface/4_serialization/po_dump_idm.md).
# PO\_Dump\_IDM
![PO Dump IDM](https://2884583650-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MaZZSUE1L_iKrqfreV9%2Fuploads%2Fgit-blob-d02a4417bd9da8c7a27c31c903ef67ce4a1e2803%2FPO_Dump_IDM.png?alt=media)
Save entire model as IDM file
## Inputs
* **model \[Required]**
  A Honeybee Model object to be written to a IDM file.
* **name \[Default]**
  A name for the file to which the honeybee objects will be written. If unspecified, it will be derived from the model identifier.
* **folder \[Default]**
  An optional directory into which the honeybee objects will be written. The default is set to the default simulation folder.
* **thickness \[Default]**
  Maximum wall thickness for internal walls
* **dump \[Required]**
  Set to "True" to save the honeybee model to a IDM file.
## Outputs
* **IDM**
  The location of the file where the IDM file is saved.
