> For the complete documentation index, see [llms.txt](https://docs.pollination.solutions/user-manual/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pollination.solutions/user-manual/rhino-plugin/pollination-commands/by-use-case/category_0.md). Agents can also search and read this documentation through its [MCP server](https://docs.pollination.solutions/user-manual/~gitbook/mcp).
# General
## PO\_CheckUpdates
Check the Pollination server for a new version of the Rhino plugin.
<figure><img src="https://discourse.pollination.solutions/uploads/default/original/2X/1/1f990db726aab9db6da3be58d857e71f0f670882.png" alt=""><figcaption><p>Check if a newer version of the plugin is available.</p></figcaption></figure>
### Useful Links
{% embed url="<https://discourse.pollination.solutions/t/best-method-of-keeping-plugins-current/1711>" %}
## PO\_LicenseManager
Activate license with a new key
## PO\_PluginInfo
Show the about dialog for displaying plugin related data.
Notes:
* It shows dependency names of the plugin and log location.
## PO\_Pollination
Turn on the main control panel for managing rooms, orphaned objects, resources (program types, constructions, schedules, etc.)
## PO\_TestLocalAppEnvironment
This command is useful to test the local App's environment. It runs Podman commands to ensure the virtual machine runs correctly before executing any local Apps.
## PO\_UnitsSetting
Show the unit dialog for setting up display units on UI.
## PO\_UploadModel
Upload the current model to Pollination cloud.
## PO\_UserManual
Open <https://docs.pollination.solutions/user-manual/rhino-plugin/getting-started>
