LogoLogo
HomeWeb PlatformForum
  • User Manual
  • Get Started
    • Create a Pollination Account
    • Setting up an Organization
      • 1. Create an Organization
      • 2. Add Organization Seats
      • 3. Add Team Members
      • 4. Purchase and Manage CAD Licenses
      • 5. Manage License Pools
      • 6. Add Additional Computing Resources
    • Setting up Rhino, Grasshopper and Revit Plugins
      • Download CAD Plugins
      • Install CAD Plugins
      • Purchase and Manage CAD Plugins
      • The Difference between CAD Licenses and Organization Seats
  • REVIT PLUGIN
    • Getting Started in Revit
    • Exporting Energy Models from Revit
      • Understanding the Export Process
      • Managing Pollination Revit License
      • Setting Up Linked Models
      • Creating Snapshots
      • Editing and Exporting Snapshots
    • Modeling Best Practices
  • Model Editor
    • What is Pollination Model Editor
    • Getting Started
    • Workflows
    • Commands
      • By Use Case
        • Room Commands
          • Edit
          • Windows
          • New
          • Adjacency
          • Line
          • Visualize
        • Line Commands
        • Roof Commands
        • Model Commands
      • Alphabetically
        • 3D preview
        • Align
        • Auto align
        • Auto top ground
        • Change units
        • Convert to room2D
        • Create boundary
        • Create rooms
        • Explode polyline
        • Export roofs
        • Fill holes
        • Find adjacency gaps
        • Find roof gaps
        • Find roof intersection
        • Floor area change
        • Generate alignment axes
        • Import roofs
        • Join coplanar faces
        • Join segments
        • Merge Small Rooms
        • Merge rooms
        • Multipliers to geometry
        • Offset
        • Offset windows
        • Preview roofs
        • Pull to room
        • Remove colinear vertices
        • Remove holes
        • Remove short segments
        • Repair windows
        • Resolve roof overlaps
        • Roof to shade
        • Separate plenums
        • Set air boundaries
        • Show tilt
        • Simplify Curved Edges
        • Simplify windows
        • Snap to grid
        • Solve adjacency
        • Split
        • Split core and perimeter
        • Subtract roofs
        • Subtract rooms
        • Validate model
        • Vertically split
    • Supported File Formats
      • Export
      • Import
    • Python Script Editor
      • Your First Python Script
      • Editor Class API Documentation
      • Available Python Libraries
    • FAQ
    • Changelog
  • Rhino Plugin
    • Getting Started in Rhino
      • Create Rooms
      • Create Apertures
      • Create Doors
      • Solve Adjacency
      • Create Shade or Context
      • Editing your Model
      • Using Room Selection Mode
    • Energy Modeling
      • Assign Program Types
      • Assign Construction Sets
      • Assign HVAC Systems
      • Energy Settings and Parameters
      • Run Simulation and Load Results
    • Daylight Modeling
      • Assign Modifier Sets
      • Assign Modifiers
      • Add Sensor Grid
      • Add View
      • Run Simulation and Visualize Daylighting Results
    • Interoperability
      • Ladybug Tools Grasshopper Plugins
        • Entity components
      • Import
        • Import HBJSON
        • Import gbXML
        • Import OSM
        • Import IDF
      • Export
        • Export HBJSON
        • Export gbXML
        • Export OSM and IDF
    • Troubleshooting
      • Rhino Plugin Errors
      • Validation Error Codes
    • Pollination Commands
      • By Use Case
        • General
        • Geometry Setup
        • Model Alignment & Updates
        • Setup & Run Simulation
        • Load, Visualize, and Export Results
      • Alphabetically
        • PO_AddApertureShades
        • PO_AddApertures
        • PO_AddAperturesByWWR
        • PO_AddBuildingShades
        • PO_AddDoors
        • PO_AddOpaqueFaces
        • PO_AddRadialGrid
        • PO_AddRooms
        • PO_AddRoomsByLayer
        • PO_AddSensorGrid
        • PO_AddShades
        • PO_AddSiteContext
        • PO_AddSkylightsByRatio
        • PO_AddView
        • PO_Align2DPlans
        • PO_AlignInElevation
        • PO_AlignInPlan
        • PO_AlignInPlan2D
        • PO_Check2DOrtho
        • PO_CheckAdjacency
        • PO_CheckPlanarity
        • PO_CheckUpdates
        • PO_ColorByBoundaryCondition
        • PO_ColorByFaceNormal
        • PO_ColorByFaceType
        • PO_ConstructionSetManager
        • PO_ConstructionManager
        • PO_DownloadModel
        • PO_DrawApertures
        • PO_DrawDoors
        • PO_DrawPlanarSurface
        • PO_DrawRoom
        • PO_DupAperturesDoors
        • PO_EditApertureProperties
        • PO_EditDoorProperties
        • PO_EditFaceProperties
        • PO_EditInPlace
        • PO_EditProperties
        • PO_EditRoomProperties
        • PO_EditSensorGridProperties
        • PO_EditShadeProperties
        • PO_EditViewProperties
        • PO_EmbedUserLibrary
        • PO_Extrude2DPlans
        • PO_FixRoomChildrenLinks
        • PO_GenAlignGrids
        • PO_GenRoomPerimeters
        • PO_HVACManager
        • PO_IsolateAdjacencies
        • PO_LicenseManager
        • PO_LoadResults
        • PO_MaterialManager
        • PO_MatchChildGeometry
        • PO_MatchRoomProperties
        • PO_MergeRooms
        • PO_ModifierSetManager
        • PO_ModifierManager
        • PO_OffsetChildObjects
        • PO_PluginInfo
        • PO_Pollination
        • PO_ProgramTypeManager
        • PO_ProjectChildToHost
        • PO_ProjectSrf
        • PO_PurgeUserLibrary
        • PO_RebuildRooms
        • PO_RemoveProperties
        • PO_RemoveShortSegments
        • PO_RebuildAperturesDoors
        • PO_ResetBoundaryCondition
        • PO_ResetDisplayName
        • PO_ResetIdentifier
        • PO_ResetLegendLocation
        • PO_ResetResourceIDs
        • PO_RunSimulation
        • PO_SaveToUserLibrary
        • PO_SelApertures
        • PO_SelDoors
        • PO_SelOpaqueFaces
        • PO_SelRooms
        • PO_SelSensorGrids
        • PO_SelShades
        • PO_SelSiteContexts
        • PO_SelViews
        • PO_SetAirBoundariesByGuides
        • PO_SetRoomStoryByElevation
        • PO_ShowObjectNotes
        • PO_SHWManager
        • PO_ScheduleManager
        • PO_SimulationParameter
        • PO_SolveAdjacency
        • PO_SplitRooms
        • PO_SyncModel
        • PO_TestLocalAppEnvironment
        • PO_UnitsSetting
        • PO_UploadModel
        • PO_UserManual
        • PO_ValidateModel
  • Grasshopper Plugin
    • Download and Install the Grasshopper Plugin
    • Grasshopper User Interface
      • 1:Primitives
        • PO_Aperture
        • PO_Door
        • PO_Face
        • PO_Model
        • PO_Room
        • PO_SensorGrid
        • PO_Shade
        • PO_View
        • PO_VisualizationSet
        • PO_Construction
        • PO_Material
        • PO_Modifier
        • PO_ModifierSet
        • PO_ProgramType
        • PO_Schedule
      • 2:Pollination
        • Check_Run_Inputs
        • Check_Run_Results
        • List_Run_Assets
        • Setup_Runs
        • User_Data
        • Pollinate
        • Check_Study_Status
        • List_Studies
        • Add_a_project
        • Get_a_project
        • List_Project_Assets
        • Load_Assets
        • Upload_Assets
        • Login
      • 3:Parametric
        • Fly
        • Fly_ID
      • 4:Serialization
        • PO_Dump_GEM
        • PO_Dump_IDM
        • PO_Dump_INP
        • PO_Dump_SDD
    • Your First Simulation
    • Create a Parametric Run
    • Visualize Results
  • Web Platform
    • Create a New Project
    • Manage Access to a Project
    • Create a New Study
    • Create Teams
  • Developers
    • Create an API Key
    • API
      • Add Members to an Organization
      • Schedule a Study on Pollination
    • Apps
      • Create a Simple Chart
      • Create a Filtered Chart
      • Create a Study
      • Check Study Status
      • Download an Output
      • Visualize Results on the Web
      • Integrate the Pollination Viewer
      • Visualize Results in Rhino
      • Prepare an App folder
      • Deploy an App using the Command Line
      • Deploy an App using Github
      • Automate the App Deployment
      • Update an App
  • Legal
    • Terms of Service
    • Privacy Policy
    • Subprocessors
    • Data Processing Addendum
    • Service Level Agreement
Powered by GitBook
On this page
  • Checking out a license from the license pool
  • Returning the license to the license pool
  • Auto Activate option
  1. REVIT PLUGIN
  2. Exporting Energy Models from Revit
PreviousUnderstanding the Export ProcessNextSetting Up Linked Models
Last updated 1 month ago
Before getting started, you need to make sure to have access to a valid license to use the Pollination Revit plugin. If you haven't used the Revit plugin in the past, you can use a 14-day free trial to test the plugin. You will need to buy a Pollination Revit license to use the Pollination Revit plugin after the trial period.
In either case, you can use the Pollination License Manager to retrieve a license from a license pool or return the license to the license pool.
To activate your license:
  1. Go to the Pollination tab, and click on the License Manager button.
  2. Click on the Sign in button, and sign in to your Pollination account using a web browser.
  3. You should see your account name in the first button if the login is successful.
    In some cases, after logging into your account, the License Manager UI might be behind the Revit UI. Use the Windows key + Tab to find the License Manager.
  4. Click on Retrieve License to check out a license from the license pool. If you have access to more than one license pool, you will see a pop-up window to select one of them.
  5. If successful, you will see a green text that says "Your license is valid!". You can close out the window and start using the plugin.
The Pollination Revit plugin tries to return the license to the license pool automatically when you close Revit. You can also use the License Manager to return the license to the license pool at any point. Click on the License Manager button, and click on Return License.
The License Manager provides an Auto Activate option for the users who use the plugin frequently.
If this option is selected, the plugin tries to check out a license from the license pool automatically every time the user opens Revit. This option is unchecked by default, and you should only select it if:
  1. You use the plugin very frequently.
  2. Your organization has enough licenses, so you don't block the other users from using Pollination.
Valid license
